Connecting 2 1720 routers with 1dsu t1
Apr 4th, 2007
For sometime now ive been trying to connect 2 1720 routers together with 1dsu t1 card. I know the T1 crossover cable is correct. But I cant seem to get the configuration right. Ive tried clock rate's service-module commands and just cant get it to work, there has to be something Im missing. I need to get them to work like a DTE and DCE.
Im trying to do the labs for Phase 3 & 4 at home. At school we have the serial WAN cards, DCE and DTE are configured easily. Ive tried packet tracer 4 but it does not always work with option.
spremkumar Wed, 04/04/2007 - 20:07
  • Red, 2250 points or more
hi
whats the interface status on both the routers ?
can you post the output of show interface serial x/x and also show controller serial x/x from both the routers ?
Also post the running config of both the routers ..
regds
jmaurer1205 Sat, 04/07/2007 - 15:02
RTR_A
RTR_A#sh run
Building configuration...
Current configuration : 753 bytes
! Last configuration change at 11:55:09 UTC Tue Feb 6 2007
! NVRAM config last updated at 11:55:13 UTC Tue Feb 6 2007
version 12.3
hostname RTR_A
boot-start-marker
boot-end-marker
memory-size iomem 25
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0
no ip address
shutdown
speed auto
interface Serial0
service-module t1 clock source internal
service-module t1 timeslots 1-24
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
RTR_B
RTR_B#sh run
Current configuration : 666 bytes
! Last configuration change at 01:38:35 UTC Sun Nov 26 2006
! NVRAM config last updated at 01:39:29 UTC Sun Nov 26 2006
version 12.3
hostname RTR_B
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip address
shutdown
speed auto
interface Serial0
ip address 192.168.1.2 255.255.255.0
no fair-queue
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
RTR_A
Serial0 is down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:27:39
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 45 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=dow
RTR_B
Internet address is 192.168.1.2/24
Last clearing of "show interface" counters 00:28:34
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 output errors, 0 collisions, 47 interface resets
DCD=down DSR=up DTR=up RTS=up CTS=down
jmaurer1205 Sat, 04/07/2007 - 15:05
All that I am trying to do is get these 2 routers to talk to one another with the WIC-1DSU-T1 cards, Simulating having the serial WIC-2A/s card with the DTE and DCE cables.
With the WIC-2A all I needed was the IP clock rate and that was it. I need one router with an IP being the DCE and the other one will act as the DTE. Then i can configure want I need for the lab.
jmaurer1205 Mon, 04/09/2007 - 09:35
Found the problem. The RJ-45 connectors were at folt. When I cripped them down I broke the tabs going into the lines. I must have had a bad bag. Tried a differetn brand and was able to connect. Sorry for the inconvence.
