Protocols/ports opening on a Firewall
Answered Question
Apr 4th, 2007
I am testing to put an IP Phone on a switch, which is separated to the CCM by a Firewall.
I have opened SCCP (TCP 2000) and RTP (UDP 19384 and 32768), and TFTP.
I does not work.
Did I have forget something? Could you tell me exactly what I have to open and in which direction?
Thanking you in advance
Correct Answer by Brandon Buffin about 9 years 11 months ago
One problem with the information above is that RTP uses ports 16384 - 32768. Also, take a look at the Signaling, Media and Other Communication Between Phones and CallManager section of the following link. It gives the ports and directions for phone to CCM communication.
http://www.cisco.com/application/pdf/en/us/guest/products/ps5820/c1693/ccmigration_09186a00807217e1.pdf
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 04/04/2007 - 09:40
  • Purple, 4500 points or more
Brandon
