snmp-server command to increase solution hardening
Apr 4th, 2007
could you please tell me wich is the command in order to avoid the possibility that users that have only the RO (read only) snmp password priviledge, to read the community psw RW.
Is it snmp-server view....? Do yo have same example?
tks a lot,
Simone
avmabe Wed, 04/04/2007 - 08:55
  • Bronze, 100 points or more
If someone only has the SNMP Read-Only password they cannot find out or view the Read-Write password.
In addition, I recommend using access-lists to limit access to both RO and RW snmp access...
just put the ACL number after the snmp-server community "password" 5 <-- where 5 is an ACL that is defined.
