lms 2.6 dbase move from C to D partition
I have an existing install of lms 2.6 on the C drive. Not sure if installing to other drive that C was even an option, hopefully it is, can someone please confirm?
option 1: backup, re-install to D drive then restore the backup
option 2: if possible, move the dbase from C to D partion.
I'm leaning towards option 2. If it is possible, can someone kindly provide the procedure or links to it?
Thank you,
Allan
Joe Clarke Wed, 04/04/2007 - 09:38
Your only viable option is 1, and it is supported, and should work.
