Rob Huffman Wed, 04/04/2007 - 10:09
Hi CF,
I'm not sure what document you are looking at, but in all the cases that I can think of the Port will remain Busied-out until specifically put back in service (for example shut/no shut). If there is a method to busy-out the port then there must be a mechanism to un-busy the same port and put it back in service.
Hope this helps!
Rob
ciscoforum Wed, 04/04/2007 - 13:02
What I meant is whether the router will bring the port back automatically when the interface or remote ip is back? How quick it is, is there a time you configure etc
