Accessing IDSM from 6500
Apr 4th, 2007
I am having trouble with an IDSM in a 6500. I recently installed an IDSM in my 6500. I had used the IDSM elsewhere in my network. I sessioned into the IDSM and decided to clear the configuration and start fresh since the IDSM will be monitoring new networks. From the IDSM I issued the erase current-config command and reset (rebooted) the IDSM. Now from the 6500 I show the IDSM to be powered down. My trouble is getting the IDSM to power up. How? I see several boot options but have not been able to get the IDSM to power up.
example: hw-module module 8 boot (config-register, eobc, flash, rom-monitor).
Suggestions?
rmeans Thu, 04/05/2007 - 05:30
I was able to look at the module/blade. The IDSM module did not show any status/shutdown lights. I removed and reset the IDSM in the 6500. The IDSM powered up and I now have access.
marcabal Thu, 04/05/2007 - 21:07
  • Cisco Employee,
For future reference hdd:1 is the partition you wanted:
hw-module module module_number reset hdd:1
But you could also just leave off the hdd:1, and it should boot the default (which is hdd:1 for the IDSM-2):
