cam monitor/notification syslogs
Apr 4th, 2007
Is there any way to get a syslog message when a cam entry is added instead of the usual snmp trap on a 6500? If I must use snmp does anyone know the specific format of the message? (ie it looks to me like there's 3 bytes prefix and postfix to a list of macs learned????) Setting the logging level of earl (who is earl anyways?) to debug gives me only the "%EARL-7-MAC_NOTIF_SLEEP:Process is going to sleep for the next 15 seconds" messages, but nothing with the actual mac in it.
bitterman Mon, 04/09/2007 - 12:37
snmp format:
cmnHistMacChangedMsg OBJECT-TYPE
SYNTAX OCTET STRING (SIZE(1..254))
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"This object contains the information of a MAC change
notification event. It consists of several tuples packed
together in the format of '...'.
Each tuple consist of 11 octets in the format of
'' where
is of size 1 octet and supports the following values
0 - End of MIB object.
1 - MAC learnt.
2 - MAC removed.
is VLAN number of the VLAN which the MAC address is
belonged to and has size of 2 octet.
is the Layer2 Mac Address and has size of 6 octets.
is the value of dot1dBasePort for the
interface from which the MAC address is learnt and has size
of 2 octets."
::= { cmnHistoryEntry 2 }
