04-04-2007 10:32 AM - edited 03-14-2019 08:50 PM
Folks,
I have 2 questions I would appreciate if someone could assist me.
1) on ccm 4.2 if I have have call forwall all, call forward busy, call forward no answer all pointing to another extension on the same phone and that line does not answer, what number is used by callmanager when redirecting the call to unity? the original number or the number the call was forwarded to?
does the behaviour change if the call is forwarded to another phone with all three senaios?
04-04-2007 10:38 AM
It should be the line that the call was forwarded to I believe. There is a way to check this for sure. In unity if you open Cisco Unity Tools depot and then Switch integration tools there is a tool called Call Viewer. This tool will show all calls being forwarded to unity. This will tell you for sure what number Unity is seeing.
Please rate helpfull posts.
04-04-2007 10:49 AM
Are you 100% sure? or guessing.
04-04-2007 10:52 AM
If you want to know for sure then use the tool that I mentioned.
Jason
04-04-2007 11:25 AM
Hi Tarun,
Unity sees the Original Redirecting (original called) number.This is a question that comes up all the time and this behaviour does not change in current 4.x Unity versions.
Have a look at Michaels excellent posts, (ECSBU Test Engineer, CISCO SYSTEMS )
"The situation you describe here (getting Unity to recognize the last forwarding station rather than the first forwarding station), will be a system-wide option added to Unity 5.0. There is not a way to do this with a configuration setting on earlier versions of Unity. I'm not aware of any CallManager settings that will address this issue either."
"We use the OriginalCalledParty and OriginalCdpnRedirectReason fields in SCCP StationCallInfo message from CallManager. The feature in Unity 5.0 will allow admin to configure Unity to look at LastRedirectingParty and LastRedirectingReason fields instead, on a system-wide basis."
From this recent thread;
Also, here is another reference to this exact question with an answer from the Unity Guru Jeff Lindborg;
Hope this helps!
Rob
04-04-2007 11:30 AM
Rob,
Many thanks for the response. Will this behaviour change if the call went to another phone (call forward all,busy, or no anwser) and the other phone did not answer. Would the caller her the voice message from the phone he called originally or the redirected phone?
04-04-2007 01:14 PM
Hi Tarun,
In the scenario you referred to, the caller would hear the voicemail of the originally called number/phone. As noted, this behaviour can be changed in the newest Unity version 5.x
Hope this helps!
Rob
