IPSEC tunnel between PIX 6.4 and PIX 7.0
I have a working IPsec tunnel between a PIX version 6.4 PIX 7.0 the problem is if the tunnel goes down for any reason only traffic coming from the PIX ver 7.0 side will bring the tunnel back, no traffic from the PIX ver 6.4 side will bring up the tunnel.
Once the tunnel is up everything works fine.
isakmp nat-transveral is enabled on both sides.
Any ideas would be appreciated.
KLW
bwilmoth Tue, 04/10/2007 - 06:36
  • Silver, 250 points or more
I think you have not defined interesting traffic from the PIX 6.4. You can issue the write terminal command on the PIX, and find the match address command under the crypto map for the connection. The Access Control List (ACL) that this command refers to specifies the interesting traffic.
