EIGRP vs Static routing issue
Apr 4th, 2007
I have certain /30 blocks that I need to be static routed through a particluar SVI on my core router. This router participates in my EIGRP AS on another SVI. When I add the static route for the /30 block...10.194.14.44/30 for instance and then do a sho ip route for that block, .44,.45, & .47 show up correctly. It is the .46 address which is which is a VOIP gateway hanging off my DS3 router, that is being redistributed by EIGRP. My DS3 router also participates in my EIGRP AS, but that /30 network is not configured to be advertised on it.
Basically, I don't want certain interface IP address's on my DS3 router to be advertised in my EIGRP AS, because I need them to take a different route from the core.
I know this is just a brief explanation of what is happening, I just figured I am probably missing somthing simple.I can be more detailed about my configurations if I have to. Any help would be apprecaited! Thanks!
Core:
ip route 10.194.14.44 255.255.255.252 10.194.15.42
interface Vlan10
description VLAN10 Flex-T1
ip address 10.194.15.41 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
CT3 Router:
interface FastEthernet0/0.2
description Vlan 10 - SONET Flex-T1 Subnet to Core
encapsulation dot1Q 10
ip address 10.194.15.42 255.255.255.248
no ip unreachables
no snmp trap link-status
interface Serial1/0/8:0
description ####
bandwidth 1544
ip address 10.194.14.45 255.255.255.252
encapsulation ppp
ip policy route-map Flex-T1
fair-queue
route-map Flex-T1 permit 10
set default interface FastEthernet0/0.2
set ip default next-hop 10.194.15.41
show commands:
sho ip route 10.194.14.44
Routing entry for 10.194.14.44/30
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 10.194.15.42
Route metric is 0, traffic share count is 1
sho ip route 10.194.14.45
* 10.194.15.42
****sho ip route 10.194.14.46****
Routing entry for 10.194.14.46/32
Known via "eigrp 100", distance 90, metric 2170112, type internal
Redistributing via eigrp 100
Last update from x.x.x.x on Vlan15, 4d22h ago
* x.x.x.x, from x.x.x.x, 4d22h ago, via Vlan15
Route metric is 2170112, traffic share count is 1
Total delay is 20010 microseconds, minimum bandwidth is 1544 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 96/255, Hops 1
sho ip route 10.194.14.47
* 10.194.15.42
Overall Rating: 4 (1 ratings)
sundar.palaniappan Wed, 04/04/2007 - 11:57
  • Green, 3000 points or more
The problem lies here..
Routing entry for 10.194.14.46/32 --> Host route takes precedence over the route with a /30 bit mask.
Last update from x.x.x.x on Vlan15, 4d22h ago --> Check the device connected via Vlan 15 why is it advertising a /32 (host) route for 10.194.14.46.
A workaround solution while you work on fixing the source of the issue is to put a distribute list and block the host route in the core switch.
router eigrp 100
distribute-list 10 in vlan 15 --> where 10 is the access list #. Make sure access list isn't already being used in the switch and if it is use a different #.
access-list 10 deny 10.194.14.46
access-list 10 permit any
Also, make sure there's no inbound distribute list applied under eigrp process for vlan 15. If there's one then you can modify the existing distribute list to deny this host route from being learnt via vlan15.
Sundar
eknell Wed, 04/04/2007 - 12:14
I do have a static route on my DS3 router, but it is routing another another block to 10.194.14.46.
ip route X.X.X.X 255.255.255.252 10.194.14.46
10.194.14.46 is bound to my equipment on the end of that T1. It is just basically an Ethernet rail between .45 (Serial Int) and .46 (VOIP IAD). I have to route a public /30 to that device as that is also the internet gateway for my cleint.
Any ideas?? Thanks for the ACL by the way..
sundar.palaniappan Wed, 04/04/2007 - 12:26
I see the problem.
Try adding this command on the CT3 Router and post the results;
CT3 Router:
no peer neighbor-route --> add this command
Sundar
eknell Wed, 04/04/2007 - 12:58
Sorry...No go??
description
bandwidth 1544
encapsulation ppp
fair-queue
"show ip route 10.194.14.46" on Core:
Last update from x.x.x.x on Vlan15, 00:06:55 ago
* x.x.x.x, from x.x.x.x, 00:06:55 ago, via Vlan15
"show ip route 10.194.14.46" on DS3 Router
Known via "connected", distance 0, metric 0 (connected, via interface)
Advertised by eigrp 100
* directly connected, via Serial1/0/8:0
Just an FYI though.... I did try your first suggestion using the ACL and the distribute-list command and that worked great!!!! I did change it up a little though, instead of blocking "in" on my core, I blocked it "out" on my DS3 router.
DS3 config:
access-list 15 deny 10.194.14.46
access-list 15 permit any
router eigrp 100
redistribute static
network x.x.x.x 0.0.3.255
network x.x.x.x 0.0.0.255
network x.x.x.x 0.0.0.7
network x.x.x.x 0.0.0.31
network x.x.x.x 0.0.0.127
network x.x.x.x 0.0.31.255
distribute-list 15 out FastEthernet0/0.15
no auto-summary
"sho ip route 10.194.14.46" on Core
* 10.194.15.42
Man, I really appreciate your help!! That has been driving me crazy! If you happen to have a chance, you might let me know why that was happening. I didn't think there was anything wrong with my initial configs, but? Again, I apprecaite your help!
sundar.palaniappan Wed, 04/04/2007 - 13:06
oops, that was my fault..
Configure the 'no peer neighbor-route' on the device that's connected to Serial1/0/8:0 on the DS3 router and that should take care of the problem.
Sundar
eknell Wed, 04/04/2007 - 13:15
Sorry...I wish I could man, but the device on the end of that Serial Int is an Adtran unit.. It is not a Cisco device.
Did you read my prior post though? Your previous solution worked for me! Do you not suggest me using the ACL and distribution-list?
sundar.palaniappan Wed, 04/04/2007 - 13:46
Yes, I did read your last post and glad it helped :)
Distribute-list should be fine. In fact, applying the distribute list on the DS3 router is more appropriate as that's closer to the source.
Sundar
