L3 ether channle?
Usage Guidelines
For Layer 2 EtherChannels, you must configure the channel-group interface configuration command, which automatically creates the port-channel logical interface. You cannot put Layer 2 interfaces into a manually created port-channel interface.
You create Layer 3 port channels by using the interface port-channel command. You must manually configure the port-channel logical interface before putting the interface into the channel group.
Only one port channel in a channel group is allowed.
