04-04-2007 12:44 PM
Greetings,
If the same parameter-map (type connection or http) is used on two different policy-map classes, will that create a conflict in how traffic for each of serverfarms uses persistence or inactivity timeout (script 1)?
Should we create a different instance of parameter-maps for each policy-map class (script 2)?
Script 1
parameter-map type connection inactivity_2000
set timeout inactivity 2000
parameter-map type http persistence-rebalance
policy-map multi-match L4_POLICY
class L3-4_VIP_A
connection advanced-options inactivity_2000
appl-parameter http advanced-options persistence-rebalance
loadbalance policy L7_Serverfarm_A_Policy
loadbalance vip inservice
loadbalance vip icmp-reply active
class L3-4_VIP_B
loadbalance policy L7_Serverfarm_B_Policy
Script 2
parameter-map type connection L3-4_VIP_A_connection
parameter-map type connection L3-4_VIP_B_connection
parameter-map type http L3-4_VIP_A_http
parameter-map type http L3-4_VIP_B_http
class L3-4_VIP_A
connection advanced-options L3-4_VIP_A_connection
appl-parameter http advanced-options L3-4_VIP_A_http
class L3-4_VIP_B
connection advanced-options L3-4_VIP_B_connection
appl-parameter http advanced-options L3-4_VIP_B_http
Solved! Go to Solution.
04-05-2007 11:22 PM
04-05-2007 11:22 PM
you can reuse the same parameter map.
Gilles.
