IPSec LAN-to-LAN from PIX 501(6.3.5) to VPNC 3000 rejects tunnel.
Apr 4th, 2007
I will post more data once back in the office but this is the error my VPNC3000 is showing when the IPSec tunnel tries to establish:
I've replaced the PIX 501 outside IP with 10.0.0.1, and the concentrator subnet with 10.1.0.0
18890 04/04/2007 15:09:33.190 SEV=6 IKE/201 RPT=2 10.0.0.2
Group [10.0.0.2]
Duplicate Phase 1 packet detected. Retransmitting last packet.
18892 04/04/2007 15:09:33.190 SEV=6 IKE/0 RPT=820 10.0.0.2
Group [10.0.0.2]
Responder resending last msg
18893 04/04/2007 15:09:33.310 SEV=8 IKEDBG/0 RPT=45723 10.0.0.2
RECEIVED Message (msgid=b57613b7) with payloads :
HDR + HASH (8) + NOTIFY (11) + NONE (0)
total length : 76
18895 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45724 10.0.0.2
Group [10.0.0.2]
processing hash
18896 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45725 10.0.0.2
Group [10.0.0.2]
Processing Notify payload
18897 04/04/2007 15:09:33.310 SEV=6 IKE/0 RPT=821
Received unexpected event EV_ACTIVATE_NEW_SA in state MM_ACTIVE
18898 04/04/2007 15:09:33.310 SEV=8 IKEDBG/0 RPT=45726 10.0.0.2
RECEIVED Message (msgid=83ab1615) with payloads :
HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NONE (0)
total length : 164
18901 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45727 10.0.0.2
Group [10.0.0.2]
processing hash
18902 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45728 10.0.0.2
Group [10.0.0.2]
processing SA payload
18903 04/04/2007 15:09:33.310 SEV=9 IKEDBG/1 RPT=5364 10.0.0.2
Group [10.0.0.2]
processing nonce payload
18904 04/04/2007 15:09:33.310 SEV=9 IKEDBG/1 RPT=5365 10.0.0.2
Group [10.0.0.2]
Processing ID
18905 04/04/2007 15:09:33.310 SEV=5 IKE/35 RPT=133 10.0.0.2
Group [10.0.0.2]
Received remote IP Proxy Subnet data in ID Payload:
Address 0.0.0.0, Mask 0.0.0.0, Protocol 0, Port 0
18908 04/04/2007 15:09:33.310 SEV=9 IKEDBG/1 RPT=5366 10.0.0.2
Group [10.0.0.2]
Processing ID
18909 04/04/2007 15:09:33.310 SEV=5 IKE/34 RPT=233 10.0.0.2
Group [10.0.0.2]
Received local IP Proxy Subnet data in ID Payload:
Address 10.1.0.0, Mask 255.255.255.0, Protocol 0, Port 0
18912 04/04/2007 15:09:33.310 SEV=8 IKEDBG/0 RPT=45729
QM IsRekeyed old sa not found by addr
18913 04/04/2007 15:09:33.310 SEV=4 IKE/61 RPT=2 10.0.0.2
Group [10.0.0.2]
Tunnel rejected: Policy not found for Src:0.0.0.0, Dst: 10.1.0.0!
18915 04/04/2007 15:09:33.310 SEV=4 IKEDBG/0 RPT=45730
QM FSM error (P2 struct &0x1e75390, mess id 0x83ab1615)!
18916 04/04/2007 15:09:33.310 SEV=7 IKEDBG/65 RPT=730 10.0.0.2
Group [10.0.0.2]
IKE QM Responder FSM error history (struct &0x1e75390)
<state>, <event>:
QM_DONE, EV_ERROR
QM_BLD_MSG2, EV_NEGO_SA
QM_BLD_MSG2, EV_IS_REKEY
QM_BLD_MSG2, EV_CONFIRM_SA
18921 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45731
sending delete/delete with reason message
18922 04/04/2007 15:09:33.310 SEV=6 IKE/0 RPT=822 10.0.0.2
Group [10.0.0.2]
Removing peer from correlator table failed, no match!
18923 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45732 10.0.0.2
Group [10.0.0.2]
IKE SA MM:5b0e34cb rcv'd Terminate: state MM_ACTIVE
flags 0x0001c042, refcnt 1, tuncnt 0
18926 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45733 10.0.0.2
Group [10.0.0.2]
IKE SA MM:5b0e34cb terminating:
flags 0x0101c002, refcnt 0, tuncnt 0
18928 04/04/2007 15:09:33.310 SEV=9 IKEDBG/0 RPT=45734
18929 04/04/2007 15:09:33.320 SEV=9 IKEDBG/0 RPT=45735 10.0.0.2
Group [10.0.0.2]
constructing blank hash
18930 04/04/2007 15:09:33.320 SEV=9 IKEDBG/0 RPT=45736
constructing IKE delete payload
18931 04/04/2007 15:09:33.320 SEV=9 IKEDBG/0 RPT=45737 10.0.0.2
Group [10.0.0.2]
constructing qm hash
18932 04/04/2007 15:09:33.320 SEV=8 IKEDBG/0 RPT=45738 10.0.0.2
SENDING Message (msgid=1d5c1587) with payloads :
HDR + HASH (8) + DELETE (12)
total length : 76
18934 04/04/2007 15:09:33.320 SEV=4 AUTH/23 RPT=176 10.0.0.2
User [10.0.0.2], Group [10.0.0.2] disconnected: duration: 0:00:00
mattisn0w Wed, 04/04/2007 - 14:53
The error that sticks out to me is:
Group [10.0.0.2]
I do not know if this means policy on the Concentrator or the PIX, but I believe this is the cause. Below is my PIX 501 config:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname pix3
domain-name mydomain.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol h323 1718-1719
names
access-list 102 permit ip 192.168.15.0 255.255.255.0 172.16.0.0 255.255.0.0
access-list 102 permit ip 192.168.15.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 102 permit icmp 192.168.15.0 255.255.255.0 192.168.15.0 255.255.255.0
no pager
logging on
logging timestamp
logging monitor debugging
interface ethernet0 10baset
interface ethernet1 10full
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 10.0.0.2 255.255.255.240
ip address inside 192.168.15.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 102
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.15.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map newmap 10 ipsec-isakmp
crypto map newmap 10 match address 102
crypto map newmap 10 set peer 10.1.0.1
crypto map newmap 10 set transform-set myset
crypto map newmap interface outside
isakmp enable outside
isakmp key myPSK address 10.1.0.1 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
ssh 172.16.0.0 255.255.255.224 inside
ssh 192.168.0.0 255.255.0.0 inside
ssh timeout 60
dhcpd address 192.168.15.10-192.168.15.20 inside
dhcpd dns 172.16.1.27 172.16.1.19
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
mattisn0w Thu, 04/05/2007 - 07:46
looks like the problem is related to Network Lists. I am able to establish an IPSec tunnel, but can not pass traffic now. :(
mattisn0w Thu, 04/05/2007 - 12:34
I've configured the concentrator with the following.
Configuration-> Policy Management-> Traffic Management-> Network Lists
Network List named "matt-corp" containing the following networks
172.16.0.0/0.0.255.255
192.168.30.0/0.0.0.255
Configuration-> System-> Tunneling Protocols-> IPSec-> LAN-to-LAN
LAN-to-LAN connection named "matt" with these settings:
Peers: 68.x.x.243
digital cert: none(use preshared keys)
Preshared Key: cisco123
authentication: ESP/MD5/HMAC-128
Encryption: 3DES-168
IKE Proposal: IKE-3DES-MD5
Filter: none
IPSec NAT-T: Enabled
No bandwitdh policy or routing.
Local Network: Network List "matt-corp"
Remote Network: Network List "matt-corp"
I've not made any changes to SAs(Configuration-> Policy Management-> Traffic Management-> Security Associations), or Rules (Configuration-> Policy Management-> Traffic Management-> Rules).
