5350 Sample Translation Rule
Answered Question
Apr 4th, 2007
Hi all,
The carrier is sending us 3 digits which will start with a 7, I need to change this so the pattern reaching the PBX starts with a 1. I have been looking at the translation rules and am assuming that there is something extremely easy that I can do for this.
Max
Correct Answer by Paolo Bevilacqua about 9 years 11 months ago
For the practical side:
dial-peer voice 10 pots
incoming called-number 7..
direct-inward-dial
translation-profile incoming 7to1
voice translation-profile 7to1
translate called 100
voice translation-rule 100
rule 1 /^7/ /1/
For the educational side of all that:
http://cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
good luck!
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Wed, 04/04/2007 - 15:31
  • Hall of Fame,
    Founding Member
direct-inward-dial
rule 1 /^7/ /1/
good luck!
