Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929508members
1244064discussions
Community Activity
wireless authentication
hello I am working in an environment where there is a wireless guest infrastructure configured  guest users are given access by an Administrator based on their email  there is  a requirement for a wireless printer to be given access to this guest net...
Resolved! How can i match vsmart with each Tenant
Hello team Last day i upgraded all controller  in to 20.3.5 -> 20.6.5 version as you know in 20.3.5 which use  multitenant mode , the vsmart are bind in each tenant. but when i upgarde it 20.6.5 version. the vsmart are come out side. I want to use th...
Keyboard on Samsung not working
Hello I am unable to see the message as I am typing into webx. The keyboard works and I can send the information I am unable to actually see the message as I type.  My keyboard works on all my other applications like texting.
Cisco Table Microphone Pro LAN connection?
I've went through the available documentation of the new Cisco Table Microphone Pro but I could not find if the microphone UTP/LAN cable can be connected to the same LAN of the Room codec or if it needs to be connected to the private LAN of the codec...
gfolens by Level 4
  • 28 Views
  • 0 replies
IOS-XR: Smart license 登録時の CRL fetch に失敗する
2024年4月25日 (初版) TAC SR Collection主な問題 IOS-XR で動作するルータにおいて Smart license の登録を行う際に、validation.identrust.com から CRL のダウンロードに失敗する事象が報告されています。IPv6 による疎通性がある場合にはこの問題は発生しません。CRL のダウンロードに失敗した場合には以下のようなメッセージが出力されます。  http_client[173]: %SECURITY-XR_SSL-3-CE...
IOS-XR: NSO からの SSH アクセス時に ssh_child_handler が crash する
2024年4月25日 (初版) TAC SR Collection主な問題 NSO から IOS-XR で動作する機器に SSH アクセスした際に、IOS-XR の ssh_child_handler プロセスが crash する事象が報告されています。 RP/0/RSP0/CPU0:Feb 3 02:09:05.885 UTC: SSHD_[66822]: Client closes socket connection x.x.x.x RP/0/RSP0/CPU0:Feb 3 02:09...
Repeating syslog Message and then Crash
We're seeing a continuous string of the following messages on a 9407 running 17.9.5.  Eventually the switch crashes.  I can't find any info on what these messages mean exactly and whether we're looking at a software or hardware fault.  The supervisor...
loopback for traffic measurement
I am trying to measure a link speed I have a traffic generator machine.I want my Cisco ASR-1001 to loopback the traffic to the generator,What config do I need to use?I am trying to do it in Layer 3 and there is a switch in between.
mangsto32 by Level 1
  • 250 Views
  • 9 replies
CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 85 Views
  • 4 replies
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 213 Views
  • 10 replies
