ip default-network
Apr 4th, 2007
Does anybody know what are the benefits of using the ip default-network command?
Overall Rating: 2.7 (3 ratings)
rajinikanth Wed, 04/04/2007 - 21:42
Hi ,
Using default-network command is same as using default route propagation
It is configured in routing protocol process to use the default-network when a suitable route is not found in its routing table.
Luis Melendrez Wed, 04/04/2007 - 21:52
What I have noticed is that once I use this command as follows on router A:
Router A#
router eigrp 2
ip classless
ip default-network
I will get the following on router B:
Router B#show ip route
Gateway of last resort is to network
How would I interpret that?? If there is no suitable route found on the routing table use the last resort or if you dont have a suitable route to network use How can I read this sentence added after I used the ip default-network commad?
rajinikanth Thu, 04/05/2007 - 00:36
Yes network is the last resort for any route not in routing table.
Because this is router B routing table.
it is showing the route to reach default network is via .
