Richard Burts Fri, 04/06/2007 - 06:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I have looked at what you posted and it looks to me like it is more likely a problem with your BRI than it is a configuration issue. Could you post the output of show isdn status?
Rick
noctorno Wed, 08/29/2007 - 10:05
krizal_hq#sh isdn stat
Global ISDN Switchtype = basic-net3
ISDN BRI0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 93
ISDN BRI0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x0
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
krizal_ttdi#sh isdn stat
ISDN BRI0/0/0 interface
Layer 1 Status:
SHUTDOWN
Layer 2 Status:
Layer 3 Status:
The Free Channel Mask: 0x00000000
Richard Burts Wed, 08/29/2007 - 12:07
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
It has been a long time since the original post and my response. But thanks for posting the show isdn status that I requested. Since the hq router shows:
Layer 1 Status:
DEACTIVATED
and since the ttdi router shows:
Layer 1 Status:
SHUTDOWN
this confirms my suggestion that there were issues with the ISDN. The shutdown status will certainly prevent any use of the BRI and the status of deactivated is also problematic. Resolve these issues and then lets see if the ISDN connects.
Rick
smothuku Wed, 08/29/2007 - 20:53
  • Silver, 250 points or more
Hi ,
How did you check the isdn status ?
if you observe the config of both the routers , isdn is back up for serial interface.
Either you remove backup interfce bri 0 from serial interface or shut down th serail interface to check the isdn .
Configuration wise there is no prob.
And one more thing have you configured dialer-list 1 protocol ip permit on both the routers.
Please paste the output of debusg isdn q931 after removing backup interface bri 0 from serail interface.
satish
Richard Burts Sun, 09/02/2007 - 19:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
When satish asked for the debug I believe that he expected to see dial attempts after the backup interface command was removed from the serial. Am I correct that the message at 8:21:08
*Apr 5 08:21:08.875: %SYS-5-CONFIG_I: Configured from console by krizal_ttdi on vty0 (192.9.205.88)
was the config change to remove the backup command from the serial interface?
The debug does not show any dialing activity. And in fact I believe that the debug shows that there is not any communication between the ISDN interface on the router and the ISDN switch. As I said before I believe that the issue is some problem with the ISDN interface. I suggest that you work with the ISDN provider to investigate whether there is a connectivity problem between your ISDN interface and the ISDN switch.
Rick
smothuku Sun, 09/02/2007 - 21:29
Hi ,
Rick is correct , but before checking with Telco it is better check the voltage which you are getting at NT bOx.Ideal volatge must be in between 96 to 102 V.
Better check the voltage on pin no 4 and 5 of RJ-45 Jack which was connected to Bri port on a router.
If the voltage is fine then you have to check the config of both the routers.
You can also place a test call from cisco router usin "isdn call" from config mode
last question: r u using any routing protocol in the network.
please send us debug isdn q931 after removing backup interface from serail on both ends.
i.e
int serial 0
no backup interface
satish
ciscodegama Thu, 09/06/2007 - 03:52
If problem is persistent, then please check whether ISDN Switch-type command exists in both global configuration mode and interface configuration mode..
Or you can manually check connectivity with :
Isdn test call int bri0/1
Shailesh
noctorno Thu, 09/06/2007 - 17:40
last time i try do a test call but nothing happen. i already ask my ISP to test, they said my ISDN link is working .
Richard Burts Thu, 09/06/2007 - 18:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
From the perspective of the ISP perhaps it is working on their end. From what you have posted it is not working on your end. When they tested did they send someone to your site to test from your end? If so can you start from where they were testing and check the connections carefully from there to your router. I would like to examine the possibility that something is not connected as it should be.
If you check and are sure that all the connections are ok (are the right kind of cable, is plugged into the correct port, that the connector is firmly seated, etc) then I would check things like is the switch type in the configuration correct?
Rick
