04-05-2007 01:15 AM - edited 03-03-2019 04:26 PM
04-05-2007 05:33 AM
Celso
The type 5 passwords are protected by MD5 and as far as I know there is not any way to break them.
Depending on what type of password it is, you can probably use the password recovery procedure and replace the password with a new password. But I do not think that you can break the existing password.
Rick
04-05-2007 05:33 AM
Celso
Rick
04-05-2007 05:38 AM
level 5 passwords can't be broken.
level 7 passwords are easily broken.
04-19-2007 09:34 PM
HI avmabe,
Can you please Post the Steps to break the "Level 7" Password in CISCO Router.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
04-19-2007 10:34 PM
Hi Guru,
you can do that with the help of solarwinds, try downloading the 30 dayz trail version & there u can find "decrypting the cisco password" for level 7. hope this helps.
rate this post if satisfied.
04-23-2007 05:23 AM
actually all passwords can be broken :0)
If you know how to reverse an MD-5 string...
You can attack MD-5 with many programs on the net, you will need to brute force them, so the longer and more complex your enable secret the better... check this...
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801f2336.shtml
Cisco actually offering another type of password, knowing md-5 / type5's are vulnerable.
11-16-2015 10:52 PM
