Any experience of upgrading a WLSE to WCS?
Apr 5th, 2007
Hi All,
Has anyone out there upgraded a WLSE appliance to WCS? It seems a fairly easy process going by the instructions on the site but I wonder if there are any pitfalls to be wary of?
Any advise would be appreciated.
Scott
Overall Rating: 4 (1 ratings)
emcaaman Mon, 04/09/2007 - 19:37
  • Cisco Employee,
It's works very well !
Normally you will not found any problem.
I do that 3 weeks ago, and works fine.
Be sure to have the 2 CDs with you to do the process. And you should be physically connected to the console port.
The process can't be done remotly.
The migration guide is on:
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a00806b71db.html
Emilio
lhewlett Thu, 04/26/2007 - 16:42
Emilio,
Have you tried to upgrade to the latest code since the conversion?
When I converted the WLSE to WCS, it was converted to 4.0.66. Now that Cisco has new code out there, I'm trying to upgrade but I can't start a X session. It's like the linux box is stripped to the very minimum.
I'm not sure how to start an X session now...I only know "startx"! Please help if you know how to do this! thanks.
emcaaman Thu, 04/26/2007 - 19:17
  • Cisco Employee,
Hi Linda,
When I tested, I do it with 4.0.66 or similar too.
But may be you want to wait for a couple of weeks for the new release.
Emilio
lhewlett Thu, 04/26/2007 - 19:59
Thanks for the response back.
As long as I had SSH to the box, I've already had a terminal session started (per Cisco).
I was trying to launch "startx" or "xdm" and I didn't need to.
The upgrade is pretty straight forward but make sure you choose the defaults when re-installing.
Linda
scottwilliamson Wed, 05/02/2007 - 00:17
Hi Linda,
can you tell me what you mean by "choose the defaults when reinstalling" please - is this for the wlse to WCS upgrade?
Scott
lhewlett Tue, 05/08/2007 - 08:22
This is only if you upgrade to a newer version of WCS. I just upgraded from 4.0.66 to 4.0.217. You must uninstall/re-install the WCS application, as shown in the Cisco docs. Be patient as restarting the WCS processes takes a long time!!
Taking the defaults allows you to bring up the WCS quicker otherwise you will have to go into the scripts to change the directories.
Note: if converting from WLSE, make sure you have the 2 cd's at hand with your license key!!!
scottwilliamson Thu, 06/07/2007 - 07:09
Hi Paul,
the part numbers for the version I have (4.0.66.0 for Linux) is different on each disc. Disc 1 is 80-8572-01 and disc 2 is 80-8568-01.
hope this is helpful
Scott
Trending Topics - Security & Network
