MTU limitation on Fastehernet ports on Cisco Routers
Apr 5th, 2007
Is the MTU limitation on Fastethernet ports on Cisco routers in hardware or in software.
I am trying to increase MTU size on FE port to avoid frengmentation of GRE packets exiting the interface but I get % Interface FastEthernet0/0 does not support user settable mtu.
Is there any workaround? Or is there any cisco router that supports changing MTU on Fastehernet ports (not Gigabitethernet).
Tnx
ankbhasi Thu, 04/05/2007 - 04:46
  • Cisco Employee,
Hi Friend,
Can you try changing the mtu value with "ip mtu" command?
Ankur
rais Thu, 04/05/2007 - 04:48
  • Silver, 250 points or more
FE ports should be following 802.3u standard. I don't think it will take MTU longer than what standard calls for. Payload can be max 1500 bytes.
Thanks.
