CSC-SSM static route
Apr 5th, 2007
I need to add static routes to the configuration of customer's CSC-SSM. Is there an official and supported method to do this ? I have add a script in the /etc/init.d/ folder that add the route through the "route" command. But sometimes ( I think when the synchronization is performed between the both CSC-SSM) the route is deleted and customer has to log on the module to run the script.
Can someone help me ?
Best Regards.
nicolas.dubois Thu, 04/12/2007 - 04:17
Thank you. Unfortunately, those documents don't help. In ASDM the route you configure are related to the ASA. For the other documents they don't talk about static route.
FYI, TAC told me that this static route feature isn't planned to be developped. A thng that is unbelievable for me (Windows is able to do that!!!)
