4506 enviroment temp
network_team
Hi have a loan 4506 and its in a small cabinet acting as a access switch. the temp of the unit is from 40 - 43 i feel in the summer this could rise a lot higher. I know the recommend temp of threshold is 75 degrees but has anyone had any experence if their switches go about and around 60 degress
40-43C is normal. this equal to 104-110F. you will get alarm starting at 75C=167F. i personally wouldn't want my switch to get this hot. i look for 55C=131F.
situwayne
the operating temperature is between 32-104F (0-40C). you will get alarms based on these thresholds. remember these are measured in Celsius. 60 degree celsius is pretty hot! I would not let my switch run this hot for any extensive period.
sw1#sh environment temperature
Chassis Temperature = 42 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
So my switch runs between 40 - 43 degrees do you think this is ok. at what stage should i be concerned
