Switch Cisco 500 Catylst 500 - disable port security
Apr 5th, 2007
Hello is there a way to disable the port security and bpduguard from certain port interfaces. I cant find it in the GUI, could someone let me know of the process
Craig Balfour Thu, 04/05/2007 - 08:55
  • Bronze, 100 points or more
I don't know how to disable it via the GUI but via the command-line interface you can do the following:
interface fa0/1
no switchport port-security
no spanning-tree bpduguard
Or for a range of ports you can do:
interface range fa0/1 - 4, fa0/15
derek.church Thu, 04/05/2007 - 10:55
Great, can anyone tell me how to get into the command line interface, I cant seem to telnet into this switch and I also tried a console cable but nada.
derek.church Thu, 04/05/2007 - 11:20
Looks like these particular devices dont come with a Command Line Interface, is there anyway at all to change these port settings or am I out of luck
sundar.palaniappan Thu, 04/05/2007 - 12:13
  • Green, 3000 points or more
I haven't personally used a Cat 500 series switch. But, I found this document that should help you disable port security and bpduguard. What you are seeing is the default behavior of smartport role selected for that port and you may have to change the role to something like 'other' to disable the feature(s).
Here it is for your reference;
http://www.cisco.com/en/US/products/ps6545/products_configuration_example09186a00806da6c9.shtml
Sundar
