sticky group for multiple serverfarms
Answered Question
Apr 5th, 2007
For ACE, would the inclusion of more than one serverfarm on a sticky group create a conflict for the connections to servers?
On CSM, usig the same sticky group on two different vservers will create a conflict for corresponding serverfarms.
Is this an issue on ACE - should a separate sticky group created foe each ServerFarm?
sticky ip-netmask 255.255.255.0 address source Group1
timeout 60
replicate sticky
serverfarm SF1
serverfarm SF2
serverfarm SF3
Correct Answer by Syed Iftekhar Ahmed about 9 years 11 months ago
Its same as CSM. You can have just one serverfarm per sticky group.
you should never use the same sticky group for different farms, otherwise that will break the VIP logic i.e. connections meant to serverfarm1 could end up being sent to serverfarm2.
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Thu, 04/05/2007 - 13:42
  • Blue, 1500 points or more
Syed Iftekhar Ahmed
