Cat 3524 XL PWR
Apr 5th, 2007
Can anbody tell me what the latest software release is for this switch? I have been looking through the software section and I can only find 12.0.5...is that right? Is there any other software that I could put on this? Any help is appreciated! Thanks
Overall Rating: 3 (1 ratings)
sundar.palaniappan Thu, 04/05/2007 - 12:52
David,
I am looking at the software download page and the latest version supported on the 3524 XL PWR switch is 12.0.5-WC17(ED).
Sundar
thefindjack Fri, 04/06/2007 - 04:23
Yeah that is conclusion I came to as well. I was going to try to use this switch to do some labs for my CCNP but the commands sets are very different from newer switches and I dont think I will be able to use it.
