yjdabear Thu, 04/05/2007 - 13:59
  • Gold, 750 points or more
These can be initially set when adding new devices through RME -> Administration -> Inventory -> Add Devices. These can then be changed later through RME -> Administration -> Inventory -> Change Device Attributes -> select target device(s) -> checking the box "User Fields".
bruceboardman Fri, 04/06/2007 - 09:06
Thanks for this. Do you know if there is a way to populate either these fields of others within CiscoWorks with fields set on the device configuration or with SNMP variables? The goal is to create dynamic groups based on device roll using an automated discovery.
getwithrob Sat, 04/07/2007 - 19:06
These user defined fields cannot be set in a device's configuration or with SNMP Variables.
The fields are a way to dynamically group devices when adding devices to RME by:
1)manual adds
2)imports from a CSV file containing devices and their credentials
3)imports from a DIF file containing devices and their credentials
