Music on Hold volume
Answered Question
Apr 5th, 2007
Is there anyway to change the volume of MoH on CallManager?
Correct Answer by Rob Huffman about 10 years 3 weeks ago
Hi Chris,
Here is an excellent Cisco Tech Note, pay special attention to this excerpt;
"Changes to this parameter only affect audio files that are processed after the change occurs."
From this doc;
CallManager Music On Hold Volume Adjustment
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805997bc.shtml
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 04/05/2007 - 12:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chris,
From this doc;
Hope this helps!
Rob
jgittins1 Tue, 06/12/2007 - 09:23
I wonder how you can change the volume for music on hold when its running off the flash?
thisisshanky Tue, 06/12/2007 - 09:26
  • Purple, 4500 points or more
You will have to re-record the file with lower volume. I think you can use this tool called Audacity, you can download it for free to tune the volume. Just google it.
