Anti-spoofing rule
Apr 5th, 2007
I am trying to create a antispoofing rule using message filter feature.
It is like
if ( header("from") == "@*mydomain\\.com$" ) { apply anti-spoofing rules here; }
But the rough part is to be able to whitelist certain hosts, e.g., our partners.
For example:
AND ( header("Received") != "whitelist1|whitelist2...." )
Is there a better way to do this? My concern is that this will get very long and error prone over time.
Jack
sseinfosec Thu, 04/05/2007 - 16:16
I think the question is "what are you trying to achieve?"
jaigill Thu, 04/05/2007 - 18:58
  • Cisco Employee,
What if you add all your partner ip addresses/domains to a sendergroup called 'partner_whitelist'.
Next, you can modify your existing filter to bypass spoofing checks from partner domains:
if (( header("from") == "@*mydomain\\.com$" ) AND (sendergroup != 'partner_whitelist'))
dbeste_ironport Fri, 04/06/2007 - 15:17
I would also have a look at Knowledge Base Article 115. this describes some of the risks and gives a short explanation. You will find a short filter, too.
Dirk
jack_ironport Mon, 04/09/2007 - 20:51
I forget to mention these boxes are not internet facing. Has anyone tried to use the dictionary?
