performance hit from ftp a file to switch?
Apr 5th, 2007
I plan to ftp an image file onto a 6509 switch.
CPU history indicates the highest utilization in the 72 hour period is 20%.
The image file to be FTP'd is almost 80 MB.
Is it a bad idea to FTP a file of that size onto a production switch during normal operation hours?
(BTW - I wont be deleting the current image file - There is room for both.)
Linnea
Danilo Dy Thu, 04/05/2007 - 19:22
  • Blue, 1500 points or more
80MB is a small file to FTP'd to a 6509 switch. No, there's no problem FTP'd it during production - just make sure that the switch dram and flash conform to the minimum requirement for the new image. But there is a problem reloading the 6509 switch to use the new image file during production. Schedule a downtime for it as you might encounter problem during reload to a new image - don't over-promise the downtime, give some buffer for troubleshooting and fallback.
It's good that you can retain the old image in the switch, in case something wrong happens during the reload to a new image and you can't troubleshoot it, you can fallback to the old image quickly.
Richard Burts Thu, 04/05/2007 - 19:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Linnea
I would think that FTP of the image would not be a problem. There are probably a couple of aspects of this to evaluate (if you think that my assumptions are questionable in your environment we can discuss further):
- bandwidth consumption. the FTP will consume some bandwidth, but I am assuming that the 6509 has enough capacity the the FTP will not be a serious impact. This is especially true of FTP (as compared to TFTP) since the TCP based protocol will back off if it detects congestion.
- CPU impact. receipt of the FTP packets and write to flash will take CPU cycles. probably most of the forwarding activity on the switch is done in hardware (or the fast switching path) and is not impacted by CPU consumption. And if the highest utilization was 20% I believe that you have plenty of capacity.
Rick
linnea.wren Thu, 04/05/2007 - 19:48
Thanks both...
I would definitely be scheduling downtime for the actual switchover, but thanks for your suggestions.
Rick - Will Ctrl/C or Ctrl/Z (or q?) break off the transfer? (just in case...)
Linnea
Richard Burts Thu, 04/05/2007 - 20:05
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Linnea
It has been a long time since I tried to break off an image transfer and I do not remember clearly what (if anything) worked. If I get a chance to test tomorrow I will let you know. (or perhaps someone else knows this and will tell us)
Rick
linnea.wren Fri, 04/06/2007 - 15:08
Rick, others -
I tested an ftp on a stackable.
I could not break off the transfer with Ctrl/C, Ctrl/Z, and q.
If anyone knows a key-combo that allows you to break off an ftp file transfer, I'd be glad to know of it, so I can back out if copying the 80 MB image onto the 6509 does something unacceptable to the network...
TIA
