Forwarding POTS calls to another CCME
Apr 5th, 2007
I have set up two CCME systems over the WAN. Only one of them has Unity Express, so thats where all the mailboxes reside for both systems.
I want to be able to forward calls from the PSTN for the system that doesnt have CUE to the the system that does, after hours or after no-answer.
Problem is when I set call-forward-all or call-forward-noanswer on the system that doesnt have CUE, the FXO port will just ring out.
But if I remove the forward, the local IP phone will ring, and then I can answer it and succesfully transfer the call to the other system (to an IP phone or to CUE).
I also tried setting the FXO port to plar straight to the other system. Same result...
Any ideas??
Paul.
paul_alexander Mon, 04/09/2007 - 16:16
EXT RANGE 3xx - SITE WITHOUT AIM-CUE
voice-port 0/0/0
cptone AU
connection plar opx 301
impedance complex1
telephony-service
load 7960-7940 P0030702T023
max-ephones 10
max-dn 15
ip source-address 10.0.20.1 port 2000
calling-number initiator
service phone videoCapability 1
system message Pacific Internet Aust.
sdspfarm units 1
sdspfarm transcode sessions 20
sdspfarm tag 1 mtp0018babaa49a
time-zone 5
date-format dd-mm-yy
voicemail 299
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name ******* secret **********
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp 7960 Apr 06 2007 14:25:12
EXT RANGE 2xx - SITE WITH AIM-CUE
telephony-service
no auto-reg-ephone
max-ephones 24
max-dn 50
ip source-address 10.0.10.1 port 2000
sdspfarm units 1
sdspfarm tag 1 mtp0018babaa9a6
cnf-file location flash:
time-zone 5
voicemail 299
hunt-group logout HLog
multicast moh 225.0.0.10 port 2000
dn-webedit
time-webedit
transfer-pattern .T
fac standard
create cnf-files version-stamp 7960 Apr 06 2007 14:28:52
paul_alexander Wed, 04/11/2007 - 03:44
I actually figured this one out.
When the call was being forwarded to the remote system, because the call was coming from an FXO with no caller ID it was matching the default voip dialpeer. The default voip dialpeer has h450.x supplementary services disabled!
divine007 Wed, 04/03/2013 - 02:57
I also have forwarding issues when i debug this what i have
Apr  3 10:29:09.937: //-1/3E4C383992E3/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x47D1F080, Call Info(
   Calling Number=93600193,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=322(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=687571
Apr  3 10:29:09.937: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  3 10:29:09.937: :cc_get_feature_vsa malloc success
Apr  3 10:29:09.937:  cc_get_feature_vsa count is 1
Apr  3 10:29:09.937: :FEATURE_VSA attributes are: feature_name:0,feature_time:1210674608,feature_id:646581
Apr  3 10:29:09.937: //687571/3E4C383992E3/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=93600193(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=322(TON=Unknown, NPI=ISDN))
Apr  3 10:29:09.941: //687571/3E4C383992E3/CCAPI/cc_process_call_setup_ind:
   Event=0x487FDE80
Apr  3 10:29:09.941: //687571/3E4C383992E3/CCAPI/ccCallSetContext:
   Context=0x497BF400
   >>>>CCAPI handed cid 687571 with tag 0 to app "_ManagedAppProcess_Default"
Apr  3 10:29:09.949: //687571/3E4C383992E3/CCAPI/ccCallProceeding:
Apr  3 10:29:09.949: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=322
Apr  3 10:29:09.953: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=322, Calling Number=93600193, Calling DN=-1,
   Redirect Number=251, Redirect Reason=15
Apr  3 10:29:09.953: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
Apr  3 10:29:09.953: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  3 10:29:09.953: :cc_get_feature_vsa malloc success
Apr  3 10:29:09.953:  cc_get_feature_vsa count is 2
Apr  3 10:29:09.953: :FEATURE_VSA attributes are: feature_name:0,feature_time:1210686704,feature_id:646582
Apr  3 10:29:09.953: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr  3 10:29:09.953:  feature_vsa is 48296DA8,featname is 0
Apr  3 10:29:09.953:  cc_get_feature_vsa count is 3
Apr  3 10:29:09.953: :FEATURE_VSA attributes are: feature_name:0,feature_time:1210687352,feature_id:646583
Apr  3 10:29:09.953: : Generating new featurevsa,inserting it
Apr  3 10:29:09.953:  feature call forward featname is 1
Apr  3 10:29:09.953: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  3 10:29:09.953: :cc_free_feature_vsa freeing 48299CE8
Apr  3 10:29:09.953:  vsacount in free is 2
Apr  3 10:29:09.957: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  3 10:29:09.957: :cc_get_feature_vsa malloc success
Apr  3 10:29:09.957:  cc_get_feature_vsa count is 3
Apr  3 10:29:09.957: :FEATURE_VSA attributes are: feature_name:0,feature_time:1210686704,feature_id:646584
Apr  3 10:29:09.957: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr  3 10:29:09.957:  feature call forward featname is 1
Apr  3 10:29:09.957: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  3 10:29:09.957: :cc_free_feature_vsa freeing 48299CE8
Apr  3 10:29:09.957:  vsacount in free is 2
Apr  3 10:29:09.961: //-1/xxxxxxxxxxxx/CCAPI/cc_find_feature_vsa:
Apr  3 10:29:09.961:  inside while in find feature_sa
Apr  3 10:29:09.961: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr  3 10:29:09.961:  feature_vsa is 48299F70,featname is 1
Apr  3 10:29:09.961: : updating existing feature vsa
Apr  3 10:29:09.961:  feature call basic
Apr  3 10:29:09.965: //687571/3E4C383992E3/CCAPI/ccCallDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
Apr  3 10:29:09.965: //687571/3E4C383992E3/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr  3 10:29:09.969: //687571/3E4C383992E3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47D1F080, Tag=0x0, Call Id=687571,
   Call Entry(Disconnect Cause=3, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr  3 10:29:09.969: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  3 10:29:09.969: :cc_free_feature_vsa freeing 48299F70
Apr  3 10:29:09.969:  vsacount in free is 1
Paolo Bevilacqua Wed, 04/03/2013 - 03:23
You are responding to a 6 years old thread, please open new thread for new problmes with a complete descirption of the problem, including calls flow, configuration, ISDN debiug, etc.
