Issue with dialup connection
Apr 5th, 2007
Kindly help me ,as line and group range command not accepted in 3845 router .
What will be reasion
spremkumar Wed, 04/11/2007 - 20:27
The particular feature set of your ios code may not have the support for these kinda commands better check out on which feature set/version its supported and better to have them on your router.
zahmed Wed, 04/11/2007 - 21:20
Hi Shivlu,
Do you even have an internal modem card in this 3845 for it to be able to show you tty lines towards the bottom of the config ? Unless and until you have a modem card, and the router shows you line , there is no way you would be able to define group range under group async interface.
Thanks and Regards,
