Voice VLAN and Data VLAN
Apr 5th, 2007
Dear Netpro's,
Guys I need your expertise for controlling my VLAN's no to talk to each other.
My current network what I have, in one area I created five zones, each zones have voice and data vlans and I created 4 voice vlans and 4 data vlans for each zones, how can I controlling them not to talk to each other and I want them only to talk to server farm vlans.
Your quick response and solution is highly appreciated.
Thank you and best regards
Overall Rating: 4.5 (2 ratings)
desai.jaideep Thu, 04/05/2007 - 23:18
Ideally members of different vlans would not interect with each other.
But in your case, you need to enable communications between your server vlan and user vlans.This can be achieved by implementing Intervlan routing between all your vlans.But this will enable communication between your user vlan too.So, to restrict that you can apply access-lists to allow communication with server vlans and denying everything else.
Remember that for Intervlan routing, you need to dedicate a seperate block of IPs for each vlans.
Hope that will help.
JD
JUNKSA_2 Fri, 04/06/2007 - 00:20
Dear JD,
Thank you for your immediate reply. Thanks for the info but if you can give me a sample configuration or links that I could start with would be more helpful.
Thank you
desai.jaideep Fri, 04/06/2007 - 00:38
HI
This will work only on a L3 switch.
For eg you have 2 user vlans : vlan 10 and 20
There is a server vlan 100
for intervlan routing :
int vlan 10
ip add 10.0.0.1 255.255.255.0
ip access-group 111 in
int vlan 20
ip add 10.0.1.1 255.255.255.0
int vlan 100
ip add 10.1.1.1 255.255.255.0
access-list 111 permit ip any 10.1.1.0 0.0.0.255
access-list 111 deny any any
Pls visit the following links :
For InterVLAN routing.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
For configuring access-list:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
JD
JUNKSA_2 Fri, 04/06/2007 - 20:43
Dear JD,
Thanks a lot. You deserve another thumbs up, keep up the goodwork.
Best regards.
desai.jaideep Fri, 04/06/2007 - 21:03
Dear JHUN
If I have solved your problem, You will see a drop down box indicating that this post has solved the problem. Pls click on that. These are the carrots I am earning by helping you.
JD
JUNKSA_2 Fri, 04/06/2007 - 21:20
Dear JD,
I cannot find that option in the drop down box indicating that this post is solved the problem.
The only option that I can see are the points that I can use for voting.
Can you tell me exactly where it is. I am willing to that because it is really deserve for you.
desai.jaideep Fri, 04/06/2007 - 21:33
You will see a check box called "Resolved my issue." in my posts.
If you are not getting it no problem. Leave it anyway. Concentrate on you implementation. Thats what important to you.
Bye
