desai.jaideep Fri, 04/06/2007 - 02:14
  • Gold, 750 points or more
Quick answer :
(1)There is no default password configured on any cisco router, except if its shipped with SDM preconfigured.
(2)Yes the username and password can be changed anytime conditioned that you are the authorized user.
JD
KlediBodinaku24 Fri, 04/06/2007 - 02:36
(1) that is the case
(2) what command does the change of username cisco
desai.jaideep Fri, 04/06/2007 - 02:42
If you can post ur config then I can help you more b'coz the below config is valid only when the router is authenticating users locally. If its using seperate server, then u can mess up with the config.
Telnet the router
Router>enable
Password:
Router#config t
Router(config)#username cisc0 password cisco
JD
KlediBodinaku24 Fri, 04/06/2007 - 03:40
HI JD
maybe i did not explain myself well
i know ho to create a new user and set privileges and i know i con set a new user as an level 15 privileged user and remove the cisco user.
I'm just worried if this might cause any problem
so that's why i'm asking if i can rename the user cisco
thanks and regards
desai.jaideep Fri, 04/06/2007 - 03:46
Thats what I am saying.The "username" command will create another user "cisc0".Once you have create that, you can negate the "cisco" username command.
It will not override your existing command,instead a new user with username cisco0 will be created.
Am I explaining myself clear?
JD
