How to allow connections in one direction over IPSEC tunnel
Apr 6th, 2007
I have a customer who wants to connect 4 locations with IPSEC tunnels in a full mesh using ASA 5505's. The catch is that hosts in locations A, B and C are trusted but location D is a partner location so the hosts are not fully trusted. The customer would like hosts in A, B, or C to be able to initiate connections to any host in location D but not allow hosts in location D to initiate connections to anyone in locations A, B or C.
These are all small sites so the ASAs will be the only devices available.
Does anyone have suggestions how I can accomplish this?
Jon Marshall Fri, 04/06/2007 - 07:10
Do you have control over site D VPN device ? If so just create an access-list denying traffic from D to A, B or C and apply in on the inside interface of site D device.
If you don't you could apply access-lists in an outboudn direction on A, B & C ASA devices denying site D traffic.
Jon
kseraphine Fri, 04/06/2007 - 07:48
Thanks for the reply.
I do have control over site D.
Will that still allow the return traffic for connections initiated from sites A, B and C through?
Jon Marshall Sun, 04/08/2007 - 08:49
Yes it will because the ASA is a stateful firewall. So traffic intiated from site D will be dropped. Traffic returning from site D in response to a connection initiated from one of the other sites will still work.
Jon
