Configuring multiple site-to-site tunnels on cisco ISR 2811 Router
Apr 6th, 2007
Hi all,
I am planning to configure multiple site-to-site tunnels cisco 2811 ISR router
is it possble ?
if possible how we can bind the tunnels with the interface .
in the normal way like
r1(config)#interface s1/0
r1(config-if)#crypto map R1
r1(config-if)#crypto map cisco
does it work ?
Plase suggest ...
Jon Marshall Fri, 04/06/2007 - 07:20
I hope i understand you correctly.
Yes you can create multiple VPN tunnels but you don't have separate crypto map names.
So you choose one crypto map name eg.
crypto map vpn-set 10 ipsec-isakmp
set peer x.x.x.x
set transform set xxxx
Then your next tunnel would be
crypto map vpn-set 20 ipsec-isakmp
set peer y.y.y.y
set transform-set x.x.x.x
So you use the same crypto map name and create multiple tunnels by using numbers.
Note, you don't have to go 10, 20, etc.
You can use 1,2,3 etc. if you want, it's up to you.
