temperature in LAP1242AG?
prakashj Mon, 04/09/2007 - 05:42
Hi nikil,
Normaly you can check same through WCS,If you have.If you are using autonamus you can go ahead with this command
AP # snmp-server enable traps envmon temperature
After this you can check the same through cisco works
Regds
Saji k.s
