High Availability for Dual Core 6509E
Apr 6th, 2007
I have two new 6509E's in my network.
I would like to configure them in HA mode to reduce Failover time.
Please let me know the options.
Thanks in Advance
Aniruddha
Jon Marshall Fri, 04/06/2007 - 12:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You don't say whether or not each chassis has redundant supervisors in them.
Attached is a link to configuring NSF/SSO for redundant supervisors.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008027e4cd.html
If you don't have redundant sups then could you let us know what you need.
Jon
ab_parkhi Fri, 04/06/2007 - 12:48
Hi ,
We do not have redundant Sup in 6509E switch.
I want to configure 6509E to reduce failover and convergence time.
Jon Marshall Fri, 04/06/2007 - 23:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you don't have redundant sups then failover and convergence comes down to your layer 3/layer 2 protocols.
Attached is a Cisco doc on recovery times comparing EIGRP/OSPF & layer 2.
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/cdccont_0900aecd801a89fc.pdf
Jon
Amit Singh Mon, 04/09/2007 - 20:43
  • Cisco Employee,
Aniruddha,
What is an over all topology. Do you have a three tier architecture (Access-Distribution-core) or 2- tier archi( Collapsed Access/distri-core or access-collapsed disti/core). The over-all design recommendation depends on the final architecture.
If you have a 3-tier archi, then run RPVST+ from access-distribution layer and run EIGRP or OPSF at the core layer.You can run MHSRP at the distribution layer if you have dual chassis design. If you have a single chassis with redundant sup run NSF/SSO between the redundant sup's.
If you have a tier-2 architecture, then run RPVST+ and MSHRP at the core layer and RPVST+ at the access layer.Multiple HSRP will give you the HA between the 2 chassis for multiple vlans.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/spantree.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swhsrp.htm#wp1061629
HTH,Please rate if it does.
-amit singh
