ASA-To-ASA Dynamic-to-Static IPSEC Help
I have an ASA 5510 that has a static IP with a site-to-site IPSEC tunnel to an ASA 5505 with a static IP and that works great.
However, I know need to create another tunnel from the ASA 5510 to a different ASA 5505, but this 5505 has a dynamic IP.
I need specific steps on how I go about created the tunnel to the ASA 5505 that has the dynamic IP without messing up my other tunnel. I know I need to create a Dynamic Crypto Map, but that is all I am sure of.
Please help.
It would be nice if I could do this through ASDM, but if not CLI will work just fine.
irisrios Thu, 04/12/2007 - 06:08
Refer the following configuration example,
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 3600
isakmp enable outside
access-list 100 extended permit ip source_ip 255.255.255.0 dest_ip 255.255.255.0
nat (inside) 0 access-list 100
tunnel-group DefaultL2LGroup type ipsec-l2l
tunnel-group DefaultL2LGroup general-attributes
authentication-server-group none
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map cisco 1 set transform-set myset
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
