Allowing Updates
Apr 6th, 2007
Hi guys,
I've problem with allowing the Microsoft Updates and TrendMicro OfficeScan from the internet. For your information, my organization is using Cisco ASA 5500 Firewall. Please give me some advices to solve the problem.
Danilo Dy Sat, 04/07/2007 - 02:07
  • Blue, 1500 points or more
Check the FW logs pertaining to the Microsoft and Symantec update sites (URL or IP Address) and determine what rule blocks it. You need to open host access to those sites and the necessary ports. PIX doesn't support domain object creation, therefore you have to use IP Address
5y5tadmin Sun, 04/15/2007 - 20:08
Thanks for your advice. Anyway, how do i know which port numbers that Microsoft and TrendMicro updates use from the FW logs? It just mentioned the file type that being block and the URL.
I would be very grateful if you can help me on this.
Thanks.
