Cisco 3640
Apr 6th, 2007
Hi I want to replace the DRAM for Cisco 3640,Since it is EoL,and EoS,What is teh suitable DRAM I can purchase.
Thanks and Regards,
Danilo Dy Fri, 04/06/2007 - 23:14
Though 3640 is EOS/EOL, you can still purchase DRAM replacement/upgrade for it.
Check the following links;'
The size and product number is in the links above. 3640 support up to a total of 128MB DRAM which is MEM3640-32U128D
