default gateway
Apr 7th, 2007
router---s1 switch---core switch
server
s2switch------- s3 switch
I have 2 questions:
In the s1 switch i will configure vlan and assign ports .I will configure an ip address as well. Do I need a gateway ?
S2 will be a dead switch I just need to configure 100 mbps to s3 .
What will be the config in this case
Raj
Amit Singh Sat, 04/07/2007 - 09:01
Hello Raj,
1. You need a default-gateway if you want your hosts to communicate outside their vlan.In your example, if you want your hosts to communicate to some other vlan hosts on S1 or to other hosts on S3, you need default-gateway on your hosts.
2. Howz you connectivity to router from S2.Is that an access link or trunk link.If you have multiple vlans across all the switches, you need to configure the links are trunk links.If you dont have multiple vlans config the links as the access links.
HTH,
-amit singh
rajbhatt Sat, 04/07/2007 - 09:31
HI Amit ,
Thanks for ur prompt reply .
But here is my changed config :
et me modify the diagram :
router---s1---s3(core)
server
s2---(100Mbps link)-----s4
For s1
interface Vlan1
description MANAGEMENT
ip address 10.134.21.173
interface FastEthernet0/1
description Router
switchport access vlan 36
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
description Router
switchport access vlan 37
interface FastEthernet0/3
description Router
dO i need switch port mode access commadn at all ?
Will this switch config work? I dont need default gateway in thiscase
and no hosts from different vlans will communicate
Also what type ofport will i require for router and s1
s4 and s2 will have no configs other than 100 mbps link
betweem them .If I conenct with a cross over cable and make
it trunk or access what will be my config.L2 swicth with no ip or vlan
I only need to set the port between the switches and the servers at 100 mbps .
Wht is the config for that
Amit Singh Sat, 04/07/2007 - 20:50
Raj,
You are still missing an explanation for what you want to achieve and what is the proper network topolgy that you want to make. Without a mpropoer network diagram and a correct explanation it will hard to let you know the exact configuration you would require.What type of switch is S3. Do you want inter-vlan routing to be done on router etc...
Let me try to be inline as per your descritpion. To use " switchport mode access " command, it depends on the switch that you are using.You dont need this command on 2950 switches as the ports are default to mode access.
Switch config is OK.If you want your S1 or S3 switch hosts to communicate to some other hosts outside their vlan, you need a default-gateway for sure.If you want router to do the inter-vlan routing then your switch port will be configured as trunk link otherwisie it will be an access link and the router will connect to the particular Vlan port.
Between S2 and S4 config will be like this:
Lets assume that both the switches use their port 1 for the connectivity:
For S2
switch(config)# int fa 01
switch(config-if)#switchport mode trunk
switch(config-if)#switchport trunk encapsulation dot1q <-- this command will be used depending on the switch type you have, you dont need this for 2950's.
For S4
To connect server to a particular vlan
switch(config)# int fa 0/2
switch(config-if)#switchport mode access
switch(config-if)#switchport access vlan
HTH,
-amit singh
