understanding 6509 configuation
Apr 7th, 2007
I have two 6509 switches and trying to understand the reason for the ports being configured the way they are.
There is Cisco VoIP being done throughout the network.
All of the ports are configured as shown below,(sample link port and trunk port)the only other config information is VLAN and routing config).
I understand that this is queueing being done, but do not understand the logic of why it is done the way it is.
For example, why are there multiple maps on each interface??
What are the multiple cos maps doing?
Why are there multiple numbers in each map?
Shown below:
ip cef load-sharing algorithm original
ip multicast-routing
no ip domain-lookup
ipv6 mfib hardware-switching replication-mode ingress
mls ip multicast flow-stat-timer 9
no mls flow ip
no mls flow ipv6
mls qos map cos-dscp 0 8 16 24 32 46 48 54
mls qos
no mls acl tcam share-global
mls cef error action freeze
interface FastEthernet4/41
switchport
switchport access vlan 50
switchport mode access
switchport voice vlan 250
no ip address
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 2 3 4 6 7
wrr-queue cos-map 2 2 5
mls qos trust cos
spanning-tree portfast
interface GigabitEthernet6/1
switchport
switchport trunk encapsulation isl
switchport mode trunk
no ip address
wrr-queue bandwidth 30 70
wrr-queue queue-limit 40 30
wrr-queue random-detect min-threshold 1 40 80
wrr-queue random-detect min-threshold 2 70 80
wrr-queue random-detect max-threshold 1 80 100
wrr-queue random-detect max-threshold 2 80 100
wrr-queue cos-map 2 2 6 7
mls qos trust dscp
there any information someone might be able to shed on why the config is done this way?
Overall Rating: 5 (2 ratings)
Amit Singh Sat, 04/07/2007 - 10:18
  • Cisco Employee,
Let me try explaining the configuration done on both the interfaces.
Using the above global config commands, a COS to DSCP mapping is done.
On the Fa4/41, command " wrr-queue cos-map" is used the map the traffic with a particular COS value to the egress queue of the interface. Each interface as 4 default queues to forward the traffic. I see that only 2 queues have been defined on the interface.The command " wrr-queue cos-map 2 2 5 " on the interface maps the traffic with the COS value of 2 and 5 to queue number 2 of the interface FA 4/41.
If, I were you, I would have used the voice traffic to be placed in a dedicated queue rather than using some other COS traffic along with the COS type 5 traffic. I would have done something link " wrr-queue cos-map 4 5 " to map my traffic with COS vlaue 5 to a dedicated queue number 4 on the interface.
On interface Gig 6/1, traffic mapping,schaduling and congestion avoidance is configured.
Command "wrr-queue cos-map" classifies and MAP the proper COS vlaue traffic to the respective interface queues." wrr-queue bandwidth 30 70 " defines the interface schedular's process of sending 30 frames using queue 1 and 70 frames using queue 2.Only 2 queues have been defined on the interface and as explained above you can use upto 4 queues per interface.
The command " wrr-queue random-detect " enable WRED on all the interface queues for congestion avoidance.to used the WRED droping algorithm each interface queue is defined with Max and Min threshlod values.the same has been defined on both the Queue 1 and Queue 2.
Please refer the link below for more understanding of the QOS config:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/qos.htm
HTH,Please rate if it does.
-amit singh
richmorrow624 Sat, 04/07/2007 - 10:34
Thanks for the reply,
I don't understand where you get only two queues have been applied when four are showing up in the config.
And why did you single out the
when the others are showing up first in the config?
Amit Singh Sat, 04/07/2007 - 20:14
  • Cisco Employee,
There are only 2 queues defined on the interface not the 4 queues. If you see the commands below
The first number tells you the queue which is being used to send the traffic with the respective COS vlaues. In the first command traffic with COS value of 1 will be sent to queue 1 and in the second command traffic with COS value 2 and 0 will be sent to queue 1 only. The same goes for third and the fourth command as well.There are only 2 queues defined on the interfaces.
I singled out " wrr-queue cos-map 2 2 5 " command just to take and example and explain it to you. If you see that traffic with COS vlaue 2 and 5 has been marked to use the queue 2.In the same queue voice traffic with COS 5 will queued along with the traffic with COS vlaue 2 which can make a singnificant impact on my voice traffic.I will always use a dedicated separate queue for voice traffic.
-amit singh
khchiang Wed, 06/06/2007 - 00:07
Dear Singh,
May I know the Cat 6509 qos setting with 7.X version. Only having Auto qos on 8.X
thanks advise,
KH
