Problem with my config
Apr 8th, 2007
I have the following goals of implementing my 877w:
1) Two vlans, one for wired, one for wireless.
2) DHCP giving IP leases for both vlans, using a pool for each vlan.
3) Allowing the clients of both vlans to access the internet through my adsl modem.
I worked for over 8 hours during the past two days, repeating all gui setup on cli. I reached a point where I can't verify what I did correctly and what I didn't.
Someone please, recalibrate me. This is all self effort, I'm a college student trying to learn (experiance), never got into cisco wireless or ccnp. Just basic ccna. I'm kind of, loosing out.
Here is my config:
Current configuration : 1957 bytes
! Last configuration change at 12:35:40 UTC Sun Apr 8 2007
! NVRAM config last updated at 11:21:19 UTC Sun Apr 8 2007
version 12.4
no service pad
hostname 877w
boot-start-marker
boot-end-marker
no logging console
enable secret xxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool wireless.AlKhaldi.net
network 10.99.99.64 255.255.255.192
domain-name wireless.AlKhaldi.net
dns-server 212.77.192.59
lease infinite
ip dhcp pool Wired
network 10.99.99.192 255.255.255.192
domain-name wired.AlKhaldi.net
lease infinite
shutdown vlan 2
shutdown vlan 12
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid Alkhaldi.net
vlan 1
authentication open
authentication shared
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts threshold 2312
station-role root
interface Vlan1
no ip address
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
interface Vlan2
no ip address
interface BVI1
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
shutdown
ip classless
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
timeout login response 300
logging synchronous
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Thanks in advance
wiluszm Mon, 04/09/2007 - 12:34
  • Bronze, 100 points or more
Ok... config looks good so far. I'll go out on a limb and see if I can help. It appears as though you have the right idea... but you never fully configured NAT. The only NAT statement I see is on your BVI interface. You need to set you NAT perimeters... your outside should be your DSL interface. Then you have to build a PAT pool for which clients can be translated. Why? You have configured your internal clients on private address schemes (10.x.x.x). In order for these clients to be Internet routable, you must translate these addresses to the public address of the DSL interface. This happens on most home-based routers without any configuration, but is required for Cisco's to work in an Internet environment. Lots of examples available for this... check out here: http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e51.shtml
Anymore questions let use know. Hope this helped!
-Mike
http://cs-mars.blogspot.com
