04-08-2007 05:33 PM - edited 03-17-2019 08:59 PM
Hi, imagine on a large organization you already have a voip system up and running.
Then you decide to deploy a video conferencing system.
In general, how much configuration do you expect to perform in order to deploy the video over IP successfully? Should I expect to do mainly client configuration in order to watch the video conferencing, or that is going to require router/switch configuration as well to accomodate the video traffic?
Solved! Go to Solution.
04-09-2007 05:11 AM
It depends on the type and volume of video conferencing you're talking about. If you're referring to point to point conferencing using VT advantage, the configuration will be minimal. If you're referring to multipoint conferencing using a conference controller(s), the configuration becomes more complex. With any video, it's necessary to configure QoS throughout the network. This will certainly involve router/switch configuration in order to classify, mark, and honor the markings of video traffic.
Hope this helps. If so, please rate the post.
Brandon
04-09-2007 05:11 AM
Brandon
04-09-2007 09:39 AM
Great!
It would be heavy traffic. That's a WAN network, 15,000+ nodes.
You talked about VT advantage. How about if you use something like Microsoft Live Communications Server? Do you anything about the integration and configuration needs between Cisco routers, switches if I am deploying a beast like Microsoft Live Communication servers ?
Thanks !
04-09-2007 09:57 AM
I'm not real familiar with Live Communications Server. From my understanding, it can be integrated with the Cisco Prescence server via SIP. In that case, you would want to make sure that the SIP traffic is classified, marked, and honored as control traffic across the network. The recommended DSCP marking for control traffic is CS3. To prioritize the video traffic used by LCS, you would need to see which ports are being used and mark traffic based on these ports as AF41.
Brandon
