04-08-2007 06:17 PM
Can someone please point me to the docs that shed the light on how the Cisco's NM-WAE operates?
thanks
04-08-2007 09:53 PM
Greg,
The configuration guide for the NME-WAE is located here:
If you are looking for additional information, please let me know.
Zach
04-09-2007 09:27 AM
Zach...appreciate the link...very informative and in lay man's terms...I was just wondering if u be so kind as to shed the light on the configuration "anomaly" in that article...when first setting up the nm, the article states to configure the module internal int to the router on a different subnet than the router's int to the module..and to configure the external int of the module to be on the same subnet with the router int to the module....if anything, i would think it would be reverse...
thanks again
04-10-2007 11:46 AM
Greg,
You conifgure either the internal interface or the externla interface, not both. In the Configuration Guide, are you referring to the following text:
"Setting Up Network Module Interfaces
Your first configuration task is to set up the network module interfaces to the host router and to its external links. You use these interfaces to access the module for installing and configuring the Cisco Wide Area Application Services software application."
Zach
07-04-2007 12:25 PM
That link doesn't appear to be active any more. Has it been moved?
Also, is it possible to run nme-wae modules without the Central Manager? If a Central Manager is required, what is the minimum necessary to work with? A customer has a simple two office network, and wants the minimum necessary hardware for optimization between them.
07-06-2007 10:43 PM
Here is the updated link:
Regarding your second question, the Central Manager (CM) is required for configuration of the application optimizers within WAAS. So at a minimum, you will need two NME-WAE's and an external appliance to function as the CM.
Zach
