ISDN lab
Lavanholy
Can any one suggest me for the ISDN lab setup.
Basically I want to set up a lab ,in which to show the ISDN dial back up to the participants.
Any ISDN demo kit which can be used in a lab environment.
Please suggest.
Thanks and Regards,
S.Venkataraman.
paolo bevilacqua
The problem is that you need one of these mini-BRI switches that use to connect BRI's and make calls. It is necessary because the BRI interface, data version, cannot be connected back-to-back. I do not rememeber any brand name now but a google search should help.
Hope this helps, please rate all useful posts!
desai.jaideep
Level 5
Level 5
The cisco routers you can use are :
(1)800 series (801/803)
(2)2800 series (2801 and so on) with one WIC-1B-S/T.
If you can go for second hand on ebay, get 2503 or 1721 with BRI card.
You can choose any two of above(whiever suits your pocket)
And get hold of an ISDN simulator with at least two S/T ports.For Eg BlackBox.
This will do for you.
JD
Hi JD,
Pls rate the posts if they have helped you.Also Check on "Resloveld my issue" checkbox if that had solve ur problem.
JD
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
