CCNA question ?
Apr 9th, 2007
How big can be a conf file saved in router ....
As i know the conf is in NVRAM. The test give the screen output from
sh ver
Cisco 1812 (MPC8500) processor (revision 0x300) with 118784K/12288K bytes of mem
ory.
10 FastEthernet interfaces
1 ISDN Basic Rate interface
31360K bytes of ATA CompactFlash (Read/Write)
As i know from this info there is no way to view size of nvram.....
What is the trick?
alessandroye Mon, 04/09/2007 - 07:29
In the enable mode, u can try this command
Router#dir nvram:
Directory of nvram:/
26 -rw- 4661 startup-config
27 ---- 24 private-config
32762 bytes total (28027 bytes free)
the nvram volume is 32762 bytes in the device.
fisko Mon, 04/09/2007 - 22:37
I know that...but in the question there is no option to connect to any router You just get the picture output from sh ver command
birgitschmid Tue, 04/10/2007 - 01:08
check the show version output for something like "bytes of non-volatile configuration memory".
hth
-birgit
fisko Tue, 04/10/2007 - 05:51
there is no any record about that see the output at the begining of the post
eugene.fourie Thu, 04/12/2007 - 06:01
The show version command should give you the details, but as per your screen dump, doesn't show details. Will check tomorrow.
bmbreer Thu, 04/12/2007 - 08:12
The 1812 comes with Security Device Manager (SDM). There is no nvram. The configuration files are kept in the flash. It looks like you have the default 32MB of flash.
fisko Thu, 04/12/2007 - 22:36
So the answer should be the free part of flash
