Verifying Radio model in AP
Answered Question
Apr 9th, 2007
Hi guys, just one quick question: Is there a way to see the APs radio models from the CLI? Because im trying to see if the radios are compatible with LWAPP. I know that with the convertion tool the job can be done, but I want to know for sure before atempting to do the convertion.
thanks in advance!
Correct Answer by Rob Huffman about 10 years 2 months ago
Hi Omar,
I believe the command 'show controllers' should do the trick.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 04/09/2007 - 09:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Omar,
Hope this helps!
Rob
b.julin Mon, 04/09/2007 - 13:06
  • Bronze, 100 points or more
The conversion tool does it this way:
show controller | include Radio AIR
The strings it accepts are "AIR-" followed by RM21A, RM22A, AP1131A, AP1131G, MP21G or MP31G (on the 1240 or 1250, the other units it does no check for radio type presumably because they are all supported/integrated)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
