ENTERPRISE/FW/IDS PLUS IPSEC 3DES on 2811
santipongv
I am upgrading my Cisco 2611XM router with IOS 12.3(19), ENTERPRISE/FW/IDS PLUS IPSEC 3DES feature set, to 2811. Is there a comparable IOS with similar feature set for Cisco 2811 router? Thank you.
paolo bevilacqua
Have you tried the Feature Navigator?
Hope this helps, if so please rate post!
Yes, I have. I am unable to find similar feature set.
It seems to me that you need what is called advanced enterprise services in 12.4 or 12.4T. See:
http://www.cisco.com/en/US/products/ps5854/prod_bulletin0900aecd802a9493.html
Found this post useful? Then rate it using the scrollbox below!
The feature set option listed on the software download page isn't exactly going to match what you are running the 2611XM. However, as the previous poster stated 'Advanced Enterprise Services' does comprise all the features included in the IOS you are currently using. If you are looking to stay with 12.3 version you can go with 12.3.14T7 (ED).
Sundar
