Paolo Bevilacqua Mon, 04/09/2007 - 11:12
SRNDs are your friend:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_book09186a00806492bb.html
Do not forget CCME that does 99% of all what people wants at fraction of the cost:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_implementation_design_guide_book09186a00805f05db.html
Thank you for rating all useful posts using the scrollbox below!
user-cisco Mon, 04/09/2007 - 11:23
thanks p.bevilacqua
can u help in links/docs about marketing information about IPT solution?
according to CCME do u think is it stable enough as well as ccm ?
thanks
Paolo Bevilacqua Mon, 04/09/2007 - 11:33
You can find all the marketing you want from the "products" section of CCO. Print the PDF for the desired product, put in a personalized binder, and here you go.
CCME is perfectly stable, it runs directly on the router and much quicker to configure and maintain than CM. Actually does things that CM doesn't like the 7931 phone, hunt groups with statistics, speacker pages, etc.
For sites with a small number of phones look at the newly announced series 500 that gives you all what you need with a rewritten graphical interfaces now.
